Neue Felder für die persönlichen Daten Man kann jetzt seine öffentlich einsehbare Daten genau bestimmen. Details findet ihr in in diesem Beitrag.
Yes, you can use HTTP.get command in Base. The syntax is as follows C.HTTP.get=url, where url should be replaced with valid URL. You can pass any arguments in the url.
Right now, it's not possible to use PUT or POST methods, but we will add it in near future. I think it will be available in the Logic and as a command.
