Sichtbarkeit von Variableninhalten im Display
#11 RE: Sichtbarkeit von Variableninhalten im Display
Beitrag von DOMIQ-Support »
That's right Florian, I see it now too:)
@ Xtof and everyone else who wants to access visualization via web browser remotely. You can access it remotely just to reconfigure by forwarding port 80 (or any other if you changed web port number), but you won't be able to control it and see any changes of state - visualization will be black&white when you uncheck the Edit mode option.
If you want to be able to control visualization via browser remotely you should use VPN. Just for testing you can open and forward ports 843 and 4224 but this is strongly unrecommended as a permament solution, so you do it at your own risk.
Xtof
#12 RE: Sichtbarkeit von Variableninhalten im Display
Beitrag von Xtof »
Hello Florian, hello Piotr,
these are my settings on the FritzBox:
I don't have VPN yet but my settings above do not enable access to visualisation at my remote office. Nevertheless I can access editing the screens.
Xtof
#13 RE: Sichtbarkeit von Variableninhalten im Display
Could you post a printscreen of the Users tab (you can hide usernames) ? Regarding ports, did you forward them to the Base address?
Xtof
#14 RE: Sichtbarkeit von Variableninhalten im Display
Beitrag von Xtof »
Hello Piotr,
doors are were wide open on the Base:
Finally I found out that due to IT regulations at my office, some ports were blocked at the network I connected to.
I was confused, because all variable values were visible in the status tab of the editing screen at my remote office:
[img]2[/img]
It looked exactly as in "Display" of my local network but these values were not displayed in Display of my office browser.
It works well on another network, without those restrictions!
One cosmetical thing: When I assign an empty string ('') to the displayed MEM.something variable, it is displayed as 0.
Thanks a lot for yours and Florians great support. Now my event handling on the Base can step ahead...
Xtof
#15 RE: Sichtbarkeit von Variableninhalten im Display
Beitrag von Beleuchtfix »
Christof, jetzt benötige ich was zu meinem Verständnis, auch wenn es schon geht. MyFritz! ist das eine 2. Box, auf der dann noch einmal Ports weitergeleitet werden? Eigentlich müssten die Ports an MyBase weiterleiten.
Florian, der jetzt nicht versteht, dass es geht :)
Xtof
#16 RE: Sichtbarkeit von Variableninhalten im Display
Beitrag von Xtof »
Florian,
hinter MyFRITZ! steckt bei mir die IP Adresse der BASE. Warum diese so benamt ist, weiss ich nicht. Vielleicht wegen der dynamischen Adresse, die ich über einen Dienstleister hoste?
Zusammenfassend waren zwei Ursachen ausschlaggebend dafür, dass es auf dem iOS Remote ging und auf dem externen Browser nicht:
1) Die Tatsache, dass C.LOGIC=someFunction() auf einem iOS Device problemlos läuft, aber nicht auf dem Display. Dort muss es LOGIC=someFunction() heissen. Danke Piotr!
2) Dass nicht nur auf der lokalen Fritzbox die Ports (80, 843 und 4224) freigegeben und auf das Base weitergeleitet sein müssen, wie Du richtig gesagt hast, sondern auch im "Remote Netz" diese Ports nach draußen frei sein müssen.
Mittelfristig werde ich VPN probieren.
Xtof, der von der Base begeistert ist und Florians Rolladenscripte als Vorlage für eine Raffstoresteuerung ideal findet
