2 mal Domiq Base
norden
#11 Re: 2 mal Domiq Base
Beitragvon norden » So 17. Jul 2016, 23:00
Moin Siebo,
das DOMIQ Base verschlüsselt die links/Verbindungen wenn ein Password eingegeben wird.
10. Links
Port: This field should be filled if the connection to the Base module has been redirected to a port other than the default (44544).
Password: If you fill the Password field, the exchanged data will be encrypted.
Identity: Each Base module has its own unique ID. ID serves as collateral security for data transmission between Base modules. It prevents the use of the IP address assigned to the Base module with given ID by other network devices.
Herzliche Grüße
Dieter
