LCN-Pro Zugriff über Base
coleman
#21 Re: LCN-Pro Zugriff über Base
Beitragvon coleman » So 2. Dez 2018, 11:14
Dear Domiq-Support,
Upnp Option is in use. in all of my 3 Base.
And it slow down after few weeks.
Need a reset to work fine.
MEM Variable is still working and does not loose.
mfg Marcel
#22 Re: LCN-Pro Zugriff über Base
Beitragvon DOMIQ-Support » Mo 3. Dez 2018, 13:52
@coleman - could you contact me via e-mail on pdukowski at domiq.pl?
Xtof
#23 Re: LCN-Pro Zugriff über Base
Beitragvon Xtof » Di 4. Dez 2018, 07:24
Hello,
UPnP AV is not active on my side.
Regards
Xtof
#24 Re: LCN-Pro Zugriff über Base
Beitragvon DOMIQ-Support » Di 4. Dez 2018, 09:42
In the last few days I've found some bugs related to network connectivity, so I hope this will solve any issues with connections to Base.
Xtof
#25 Re: LCN-Pro Zugriff über Base
Beitragvon Xtof » Mi 5. Dez 2018, 09:47
Hello Piotr,
I appreciate your efforts and am glad to hear it will be fixed soon. Please feel free to use my system for testing via TV 24/7.
Will the loss of MEM variables also be solved by the update?
Regards
Xtof
#26 Re: LCN-Pro Zugriff über Base
Beitragvon DOMIQ-Support » Mi 5. Dez 2018, 14:05
The issues we've found influence the overall performance of the Base module and in the worst scenario led to situation when no connection over TCP was possible (for example from configurator/LCN-Pro etc.).
Regarding MEMs being lost - patch for this issue won't be included in the nearest update because we found that this issue in not actually our mistake, but it's a problem in the zlib library we use to compress MEMs... There is a fixed version of the zlib library, but it requires update of the RTOS in Base and it's a bit tougher task - it requires much more testing on our side, so we don't want to postpone the update once again (it's already delayed:/)
