Seite 1 von 1
				#1 Ende von Flash
				Verfasst: Sa 21. Nov 2015, 11:48
				von Beleuchtfix
				Hi Filip, Hi Piotr,
Firefox is announcing to stop it's support for Flash. Windows 10 dropped the IE and stopped support for their own Silverlight. I don't know yet, how the other browser will behave.
- Do we have to fear that one of these days, we will not be able to access base any more?
- Do we have to keep an old version of Fiefox (which is rather complicated with all the automatic updates?
- are you planning a new software with html5?
- are there any problems in sight which would affect the hardware display?
Perhaps you could tell us a little about you roadmap, what we can expect in the next time
Regards Florian
				#2 RE: Ende von Flash
				Verfasst: Sa 21. Nov 2015, 15:12
				von koboldo
				:thumbup:
				#3 RE: Ende von Flash
				Verfasst: Sa 21. Nov 2015, 16:52
				von DOMIQ
				We are watching what is happening. Our plan will be to use ActionScript to HTML5 compilers when they are ready to deliver the configuration app. Until that happens Flash can be enabled for specific sites, it is also included (not as a plugin) in Chrome.
				#4 RE: Ende von Flash
				Verfasst: Sa 21. Nov 2015, 22:32
				von hocky
				Beleuchtfix hat geschrieben:Firefox is announcing to stop it's support for Flash. Windows 10 dropped the IE and stopped support for their own Silverlight. I don't know yet, how the other browser will behave.
I hope they´ll follow soon. Flash is a nightmare because of it´s permanent security flaws since years now and should have been sunset a long time ago.
It requires Flash player to be installed and this is not even available on all platforms.
If a move to HTML5 has not been considered in the past, now it´s the right time...
				#5 RE: Ende von Flash
				Verfasst: Mi 2. Dez 2015, 12:16
				von mr_claus
				Removing Flash is absoletely necessary, since years. As Adobe will stop support in future and ask developers of Flash applications to move to other technologies i would prefer to get html5 on the Base due it's supported on every platform.
				#6 RE: Ende von Flash
				Verfasst: Di 9. Feb 2016, 09:46
				von torsten.s
				Flash is a security nightmare :thumbdown:  and should be replaced by html5 as soon as possible.
If someone needs actual proof:
http://www.theregister.co.uk/2016/02/08/fake_flash_update_apple_scareware/@Filip, Piotr: Do you have any news on this for us?
Torsten
				#7 RE: Ende von Flash
				Verfasst: Mo 15. Feb 2016, 08:15
				von DOMIQ-Support
				We are thinking about the solution, but the most probably it won't be migration to HTML5...
				#8 Re: Ende von Flash
				Verfasst: So 20. Mär 2016, 10:22
				von MDWD
				Hallo. Wie geht es denn mit Domiq jetzt weiter? Muss ich damit rechnen, dass ich mit meinem Mac in Kürze nicht mehr auf die Oberfläche der Base zugreifen kann? Gibt es hier schon Neuigkeiten? VG
				#9 Re: Ende von Flash
				Verfasst: Mo 21. Mär 2016, 13:02
				von torsten.s
				Ist wirklich eine gute Frage, wie es mit der Visualisierung in Domiq weiter geht.
Leider bekommt man ja derzeit keine konkrete Aussage, wo die Reise hingehen soll.
Ich werde jedenfalls Flash in den nächsten Wochen bei mir abschalten. Zwar fühle mich mit einem Mac noch relativ sicher vor Ransomware und ähnlichem Schrott - aber potenzielle Einfallstoren wie Flash und Java sind vorhanden und müssen dicht gemacht werden.
Vielleicht muss ich aber auch über eine alternative Visualisierung (wie IPS o.ä.) nachdenken, die ohne Flash auskommt...
				#10 Re: Ende von Flash
				Verfasst: Mo 21. Mär 2016, 14:28
				von Beleuchtfix
				Du kannst doch das System so streng einstellen, dass Flash nur per Ausnahme gestartet wird, und z.B. für das Base eine dauerhafte Ausnahme einstellen, solange Flash überhaupt noch unterstützt wird.
Natürlich kann dir Domiq da einen gefährlichen Abschnitt unterjubeln, aber das kann eigentlich jeder, von dem du ein Programm installierst, egal ob das nun IPS ist, OpenHAB, ein MS-Programm oder .... Die Haiptgefahr sehe ich bei Flash beim bedingungslosen Ausführen auf allen Webseiten.
Florian, der aber auch gespannt ist, was Filip und Piotr entwickeln.
