Problem with LCN-AVN
edubht
#1 Problem with LCN-AVN
Beitragvon edubht » Mo 18. Jul 2011, 17:33
Hello
I have several AVN LCN-connected to the analog outputs of several SH.
The outputs are configured as a dimmer and linear.
The problem is to open 100% analog outputs, or use a regulator with ts. The LCN-AVN not make any movement. The upper cylinder is immobile.
Chris
#2 RE: Problem with LCN-AVN
Beitragvon Chris » Mo 18. Jul 2011, 20:47
Hello,
test the AVM as switch. After you switch the avn on you must wait 2minutes. After the 2minutes the valve has open. Please test and contact me.
Best regards
Chris
rk
#3 RE: Problem with LCN-AVN
Beitragvon rk » Mo 18. Jul 2011, 23:16
Hello,
at first our obligatory warm welcome to a new Bus-Profi member :).
I'm not sure if you see the "first open function" and description in the blurb or in german "Waschzettel". Look at the pictures on page 4. Sorry, i didn't find an English version.
Is the valve open? Did you see the indicator extended?
If so, you've been waiting for at least 6 minutes?
edubht
#4 RE: Problem with LCN-AVN
Beitragvon edubht » Di 19. Jul 2011, 10:50
Thanks chris and Rk.
The avn as switch, opens and closes to disconnect.
But with SH don't move, I waited more than 6 minutes and nothing happens.
The configuration dimmer-lineal is correct?
Attached image.
#5 RE: Problem with LCN-AVN
Beitragvon Uwe » Di 19. Jul 2011, 11:21
Hello - and WELCOME from me too :w00t:
No - not for the AVN ...
Try it with PPS in the Output Settings
The installation instructions are in English not available. I have several translations available (unfortunately not all modules). You need it? Send me a mail ... ;)
Best regards
#6 RE: Problem with LCN-AVN
Beitragvon Beleuchtfix » Di 19. Jul 2011, 12:35
Hi and welcome to the Bus-Profi Club :)
The design asks for a setup in PPS -mode. You do have to set the pps-time also, 300 seconds at the beginning is a good start.
PPS coresponds to ppc in the English language.
Regards Florian
#7 RE: Problem with LCN-AVN
Beitragvon LuckyLPA » Di 19. Jul 2011, 17:14
Hello.
Please check the voltage on output too. Make sure the output´s not defect.
greetings
PS: Number 2 and 3 looks like "first-open-mode"
edubht
#8 RE: Problem with LCN-AVN
Beitragvon edubht » Di 19. Jul 2011, 18:26
Thanks.
Uwe, Installation instructions are not necessary.
I think it's scheduling problems.
Carsten, outputs are working properly.
I will try with pps and 300sec. Now I will tell you.
And char table has to be linear?
Best regards.
#9 RE: Problem with LCN-AVN
Beitragvon Uwe » Di 19. Jul 2011, 18:35
¡Hola
linear / halogen ... it does not matter - PPS (PPC), the signal pulses ...
buena noche
edubht
#10 RE: Problem with LCN-AVN
Beitragvon edubht » Mi 27. Jul 2011, 17:45
Good evening friends.
After trying with PPC, the AVN continue without making any movement.
I'm waiting for the installer to check the installation. Could it be some other reason?
